Ga door naar hoofdinhoud
Briggs and Stratton 675 Series Spark Plug Replacement
Wat je nodig hebt
  1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: stap 1, afbeelding 1 van 2 Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: stap 1, afbeelding 2 van 2
    • Make sure the engine is turned off before beginning.
    • Use your hands to remove the spark plug wire. It should pop off easily with little effort
  2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: stap 2, afbeelding 1 van 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: stap 2, afbeelding 2 van 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: stap 2, afbeelding 3 van 3
    • Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
    • Pull the spark plug out of its housing with your hands.
    • Alternatively, you may use a wrench or pliers to remove the spark plug instead. (Shown in the second image.)
Conclusie
6 andere personen hebben deze handleiding voltooid.
Andrew Saunders
957 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-31, Amido Winter 2015 Lid van Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Leden
15 handleidingen geschreven
12 opmerkingen
I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Antwoord
Any ideas I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Antwoord
pinch the front of black cap and pull off
tracy.mullen - Antwoord
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
Eris - Antwoord
Kymberleah - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 33
Afgelopen 7 dagen: 137
Afgelopen 30 dagen: 580
Altijd: 47,142
