Ga door naar hoofdinhoud
Briggs and Stratton 675 Series Repair Air Filter Replacement
Wat je nodig hebt
  1. Briggs and Stratton 675 Series Repair Air Filter Replacement, Air Filter: stap 1, afbeelding 1 van 1
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
  2. Briggs and Stratton 675 Series Repair Air Filter Replacement: stap 2, afbeelding 1 van 1
    • Use your hands to pull the air filter case out of the hinge at the bottom.
  3. Briggs and Stratton 675 Series Repair Air Filter Replacement: stap 3, afbeelding 1 van 1
    • Simply remove the air filter with your hands.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Taichi Nakahara
397 Reputatie
1 Handleiding geschreven
Cal Poly, Team 6-31, Amido Winter 2015 Lid van Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Leden
15 handleidingen geschreven
2 opmerkingen
Good information, although it didn't resolve my issue. Thanks for sharing
all2thegoodpromo - Antwoord
This is a power wash motor water will not come out
hdoggett Doggett - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 61
Afgelopen 30 dagen: 285
Altijd: 19,581
