Ga door naar hoofdinhoud
Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement
Wat je nodig hebt
  1. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement, Pulp Basket: stap 1, afbeelding 1 van 1
    • Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
  2. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: stap 2, afbeelding 1 van 1
    • Tilt the juicer slightly to the right so the pulp basket is off of your surface.
  3. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: stap 3, afbeelding 1 van 1
    • Pull the pulp basket down and out from under the juicer cover.
  4. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement, Safety Locking Arm: stap 4, afbeelding 1 van 2 Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement, Safety Locking Arm: stap 4, afbeelding 2 van 2
    • Place one hand on either side of the safety locking arm.
    • Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
  5. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: stap 5, afbeelding 1 van 2 Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: stap 5, afbeelding 2 van 2
    • Locate the two 1 inch Phillips #1 screws on the back of the safety arm.
  6. Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: stap 6, afbeelding 1 van 2 Breville JE98XL Juice Fountain Plus Safety Locking Arm Replacement: stap 6, afbeelding 2 van 2
    • Remove the safety locking arm by gripping both sides and pulling horizontally away from the juicer.
Conclusie
Madison Burgess
499 Reputatie
3 handleidingen geschreven
Cal Poly, Team 15-1, Livingston Fall 2016 Lid van Cal Poly, Team 15-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G1
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 1,065
