Ga door naar hoofdinhoud
Breville Duo-Temp 800ESXL Gasket Replacement
Wat je nodig hebt
  1. Breville Duo-Temp 800ESXL Gasket Replacement, Gasket: stap 1, afbeelding 1 van 3 Breville Duo-Temp 800ESXL Gasket Replacement, Gasket: stap 1, afbeelding 2 van 3 Breville Duo-Temp 800ESXL Gasket Replacement, Gasket: stap 1, afbeelding 3 van 3
    • With your left hand, strongly grip the handle of the portafilter.
    • Pull the handle to your left. This will unlock the portafilter.
    • If the portafilter lock is too tight, place your hand on the top or bottom of the machine to provide additional leverage.
    • Gently push down to release the portafilter.
  2. Breville Duo-Temp 800ESXL Gasket Replacement: stap 2, afbeelding 1 van 3 Breville Duo-Temp 800ESXL Gasket Replacement: stap 2, afbeelding 2 van 3 Breville Duo-Temp 800ESXL Gasket Replacement: stap 2, afbeelding 3 van 3
    • Slide the drip tray towards you to remove and set aside.
    • Two holes in the middle of the tray are available to make the tray easier to hold on to when removing.
    • Grasp the water reservoir using the front indention and the bottom of the tank.
    • Pull the water reservoir towards you to remove and set aside.
    • The drip tray and the water reservoir may contain water. Avoid spills if possible.
  3. Breville Duo-Temp 800ESXL Gasket Replacement: stap 3, afbeelding 1 van 1
    • Carefully lay the espresso machine on its side.
    • The espresso machine is top heavy with the drip tray and the water reservoir removed.
  4. Breville Duo-Temp 800ESXL Gasket Replacement: stap 4, afbeelding 1 van 3 Breville Duo-Temp 800ESXL Gasket Replacement: stap 4, afbeelding 2 van 3 Breville Duo-Temp 800ESXL Gasket Replacement: stap 4, afbeelding 3 van 3
    • Line the Phillips screwdriver up with the screw located in the center of the group head screen.
    • Turn the screwdriver counter clockwise to remove the 6 mm Phillips #1 screw.
    • If the screw is tight, use both hands to turn the screw driver.
    • Applying pressure to the screwdriver will help prevent stripping the screw.
  5. Breville Duo-Temp 800ESXL Gasket Replacement: stap 5, afbeelding 1 van 2 Breville Duo-Temp 800ESXL Gasket Replacement: stap 5, afbeelding 2 van 2
    • Insert the opening tool between the housing and the gasket.
    • Pry the gasket loose from the housing.
    • The screen is contained within the gasket and will not be damaged by prying the gasket loose.
  6. Breville Duo-Temp 800ESXL Gasket Replacement: stap 6, afbeelding 1 van 3 Breville Duo-Temp 800ESXL Gasket Replacement: stap 6, afbeelding 2 van 3 Breville Duo-Temp 800ESXL Gasket Replacement: stap 6, afbeelding 3 van 3
    • Remove the gasket and screen from the machine.
    • Peel back the gasket from the screen in a circular motion.
    • If the gasket is firmly stuck to the screen, soak in warm soapy water for approximately 30 minutes to loosen the coffee buildup.
    • Discard the old gasket.
  7. Breville Duo-Temp 800ESXL Gasket Replacement: stap 7, afbeelding 1 van 3 Breville Duo-Temp 800ESXL Gasket Replacement: stap 7, afbeelding 2 van 3 Breville Duo-Temp 800ESXL Gasket Replacement: stap 7, afbeelding 3 van 3
    • Soak the group head screen in warm soapy water.
    • Clean the group head with a nylon espresso machine brush and warm soapy water.
    • Scrub the group head screen with a nylon espresso machine brush.
    • The group head screen should be completely free of coffee oils and build up.
  8. Breville Duo-Temp 800ESXL Gasket Replacement: stap 8, afbeelding 1 van 3 Breville Duo-Temp 800ESXL Gasket Replacement: stap 8, afbeelding 2 van 3 Breville Duo-Temp 800ESXL Gasket Replacement: stap 8, afbeelding 3 van 3
    • Place the group head screen inside the new gasket.
    • Firmly press the screen into the seal in a circular motion.
    • The screen fits snuggly but easily within the gasket.
  9. Breville Duo-Temp 800ESXL Gasket Replacement: stap 9, afbeelding 1 van 2 Breville Duo-Temp 800ESXL Gasket Replacement: stap 9, afbeelding 2 van 2
    • Place the gasket and screen back into the espresso machine.
    • Insert the 6 mm Phillips #1 screw back into the middle of the screen and tighten in a clockwise direction.
    • The tightness of the screw should be firm but not difficult to loosen. Do not over tighten the screw.
  10. Breville Duo-Temp 800ESXL Gasket Replacement: stap 10, afbeelding 1 van 2 Breville Duo-Temp 800ESXL Gasket Replacement: stap 10, afbeelding 2 van 2
    • Set the espresso machine upright.
    • Reattach the water reservoir and drip tray.
Conclusie
Your espresso machine is now ready to use. Fill your portafilter with coffee, brew and enjoy your espresso.
Carissa Baker
181 Reputatie
1 Handleiding geschreven
2 opmerkingen
thanks so much. Do you have a photo of the brew group without the screen on it? mine is so filthy and water was only coming out of one side-Lily
Lily White - Antwoord
Hi! Water is coming out of those holes on top when I try to make espresso. Does that mean I need to replace the gasket? What do you think the issue is? Thanks!
Haley Shanahan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 118
Altijd: 5,306
