Ga door naar hoofdinhoud
Breville BKC600XL Water Valve Replacement
Wat je nodig hebt
  1. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: stap 1, afbeelding 1 van 3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: stap 1, afbeelding 2 van 3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: stap 1, afbeelding 3 van 3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Breville BKC600XL Water Valve Replacement, "Top" Black Shell Piece: stap 2, afbeelding 1 van 1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Breville BKC600XL Water Valve Replacement, Silver Casing: stap 3, afbeelding 1 van 3 Breville BKC600XL Water Valve Replacement, Silver Casing: stap 3, afbeelding 2 van 3 Breville BKC600XL Water Valve Replacement, Silver Casing: stap 3, afbeelding 3 van 3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  4. Breville BKC600XL Water Valve Replacement, Water Valve: stap 4, afbeelding 1 van 1
    • Cut the band connecting the hose to the water valve.
    • Remove the water valve.
    • Reminder for reassembly; You will need a new band to tie the hose back to the water valve.
Conclusie
Antonio
120 Reputatie
6 handleidingen geschreven
Cal Poly, Team 1-3, Propen Fall 2012 Lid van Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Leden
2 opmerkingen
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Betsy Goodrich - Antwoord
Hi same question :)
Aiqui2@hotmail.com - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 27
Altijd: 5,872
