Ga door naar hoofdinhoud
Breville BKC600XL Heating Tank Replacement
Wat je nodig hebt
  1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: stap 1, afbeelding 1 van 3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: stap 1, afbeelding 2 van 3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: stap 1, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL Heating Tank Replacement, Black Water Inlet: stap 2, afbeelding 1 van 2 Breville BKC600XL Heating Tank Replacement, Black Water Inlet: stap 2, afbeelding 2 van 2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: stap 3, afbeelding 1 van 2 Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: stap 3, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL Heating Tank Replacement, Power Cord: stap 4, afbeelding 1 van 2 Breville BKC600XL Heating Tank Replacement, Power Cord: stap 4, afbeelding 2 van 2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL Heating Tank Replacement, Clear Hose: stap 5, afbeelding 1 van 2 Breville BKC600XL Heating Tank Replacement, Clear Hose: stap 5, afbeelding 2 van 2
    • Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
    • Push down on the hook and carefully move the hose from its grip.
  6. Breville BKC600XL Heating Tank Replacement, Heating Tank: stap 6, afbeelding 1 van 1
    • Carefully pull out the heating tank by hand.
    • The heating tank may still be hot. Exercise caution when grabbing hold of the tank. If necessary, wait four to six hours after last use.
    • Reminder for reassembly; You will need a new band to tie the hose back to the heating tank.
Conclusie
Antonio
120 Reputatie
6 handleidingen geschreven
Cal Poly, Team 1-3, Propen Fall 2012 Lid van Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 4,639
