Ga door naar hoofdinhoud
Brentwood TS-292B Bread Grabber Spring Replacement
Wat je nodig hebt
  1. Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: stap 1, afbeelding 1 van 2 Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: stap 1, afbeelding 2 van 2
    • Turn the toaster upside down.
    • Remove the five 6 mm screws with a Phillips #2 screwdriver.
  2. Brentwood TS-292B Bread Grabber Spring Replacement: stap 2, afbeelding 1 van 2 Brentwood TS-292B Bread Grabber Spring Replacement: stap 2, afbeelding 2 van 2
    • Grasp the plastic pull lever cover firmly and pull to remove it. This may require force.
    • Lift the cover upwards to remove it.
    • When removing the cover, do not damage the cable connector bundle that attaches the cover to the toaster.
  3. Brentwood TS-292B Bread Grabber Spring Replacement: stap 3, afbeelding 1 van 1
    • To detach the bundled cable connector, carefully pull it away from the circuit board.
  4. Brentwood TS-292B Bread Grabber Spring Replacement: stap 4, afbeelding 1 van 2 Brentwood TS-292B Bread Grabber Spring Replacement: stap 4, afbeelding 2 van 2
    • Pull the toaster lever down.
    • While holding the toaster lever down, use the spudger to pull the metal tabs away from the wired bread grabber.
    • Continuing to hold the toaster lever down, pinch the wires inward and pull up to carefully remove them from the toaster.
Conclusie
Elly Ayala
739 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 365
