Ga door naar hoofdinhoud
Braven BRV-X Battery Replacement
Wat je nodig hebt
  1. Braven BRV-X Battery Replacement, Bottom Outer Casing: stap 1, afbeelding 1 van 3 Braven BRV-X Battery Replacement, Bottom Outer Casing: stap 1, afbeelding 2 van 3 Braven BRV-X Battery Replacement, Bottom Outer Casing: stap 1, afbeelding 3 van 3
    • Flip the Braven BRV-X upside down so you are facing the bottom side.
    • With the H1.5 Head Screwdriver, unscrew the four screws.
    • All screws on this device can be stripped easily. Hold your screwdriver with the thumb on top and swivel with the opposite hand's thumb and index finger.
    • Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
    • Gently remove the outer casing, which should reveal the inner shell.
  2. Braven BRV-X Battery Replacement: stap 2, afbeelding 1 van 2 Braven BRV-X Battery Replacement: stap 2, afbeelding 2 van 2
    • With a Jimmy, cut the two warranty seals on either side.
    • You may also use a tech knife instead of a Jimmy.
    • WARNING: Once warranty seals are broken, you may no longer return the product.
    • Next, remove the 18 screws with a #00 Phillips screwdriver.
  3. Braven BRV-X Battery Replacement: stap 3, afbeelding 1 van 2 Braven BRV-X Battery Replacement: stap 3, afbeelding 2 van 2
    • Using two plastic opening tools, slide under the cover and slowly lift.
    • There is glue nearly all around the inner shell, so strength will be necessary. When both tools are inserted, you can slide out along the edges.
  4. Braven BRV-X Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the black foam squares from the red, yellow, and black wire on the top right side of the device.
  5. Braven BRV-X Battery Replacement: stap 5, afbeelding 1 van 3 Braven BRV-X Battery Replacement: stap 5, afbeelding 2 van 3 Braven BRV-X Battery Replacement: stap 5, afbeelding 3 van 3
    • Now that the three wires are exposed, follow the wires to the white base that is plugged into the motherboard.
    • Using the tech knife, carefully remove the glue that keeps the plug in place.
    • Using the tweezers, carefully disconnect the plug from the motherboard.
    • WARNING: Make sure the battery is drained of all power for safety reasons.
    • There should still be a small white base attached to the motherboard, where the plug will eventually be plugged back in.
  6. Braven BRV-X Battery Replacement: stap 6, afbeelding 1 van 1
    • The battery's black shell is connected to the motherboard with four screws. Use the #00 Phillips screwdriver to remove the four screws.
    • The screws near the speaker side of the device will be a tight squeeze to get to.
  7. Braven BRV-X Battery Replacement: stap 7, afbeelding 1 van 1
    • Now, you should be able to lift the battery along with the black container up.
    • Pull the battery pack straight out so you do not damage other wires or the motherboard.
  8. Braven BRV-X Battery Replacement: stap 8, afbeelding 1 van 1
    • Slide the blue battery out from the black container. Your battery is now removed from the device and is ready for replacement.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Courtney Crockett
318 Reputatie
2 handleidingen geschreven
Texas Tech, Team 19-4, Rauch Fall 2015 Lid van Texas Tech, Team 19-4, Rauch Fall 2015
TTU-RAUCH-F15S19G4
4 Leden
10 opmerkingen
Thank you for the replacement steps - do you know where I could buy a replacement battery?
jmckeag7 - Antwoord
Anyone ever figure out what battery they needed?
Aaron Eisenbarth -
I also would love to know what battery is actually needed for this.
grenchpickle - Antwoord
The batteries are two 18650's in tandem. You can get these from batteries plus
nick - Antwoord
Parallel or series connection?
Vladimir Skrbic -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 72
Altijd: 9,792
