Ga door naar hoofdinhoud
Braven BRV-1s Speaker Cone Replacement
Wat je nodig hebt
  1. Braven BRV-1s Speaker Cone Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • To remove the outer case, remove 4 phillips screws (Phillips #00 headtype, 9.3mm long)
  2. Braven BRV-1s Speaker Cone Replacement: stap 2, afbeelding 1 van 1
    • Using a metal spudger, gently pry the side of the defective case.
  3. Braven BRV-1s Speaker Cone Replacement: stap 3, afbeelding 1 van 1
    • Still using the metal spudger, continue to work your way around the outer case.
  4. Braven BRV-1s Speaker Cone Replacement: stap 4, afbeelding 1 van 1
    • Remove the broken outer case. Replace with used/new out case.
    • Note that unless properly sealed with glue, the speaker will no longer be water resistant.
  5. Braven BRV-1s Speaker Cone Replacement, Speaker Cone: stap 5, afbeelding 1 van 1
    • To remove the speaker cone plate, remove 10 phillips screws (Phillips #00 headtype, 9.3mm long)
  6. Braven BRV-1s Speaker Cone Replacement: stap 6, afbeelding 1 van 1
    • Using a metal spudger, gently pry the side of the defective speaker cone plate.
    • Remember to pry all around the side of the speaker cone plate.
    • Keep in mind that the adhesive will make it difficult to pry the plate off. To loosen the adhesive, heat the plate with a device such as a hair dryer.
  7. Braven BRV-1s Speaker Cone Replacement: stap 7, afbeelding 1 van 2 Braven BRV-1s Speaker Cone Replacement: stap 7, afbeelding 2 van 2
    • Remove the broken speaker cone plate. Replace with used/new out plate.
Conclusie
Leanne Abel
101 Reputatie
1 Handleiding geschreven
IUPUI, Team S2-G2, Harley Spring 2017 Lid van IUPUI, Team S2-G2, Harley Spring 2017
IUPUI-HARLEY-S17S2G2
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 718
