Ga door naar hoofdinhoud
Braven BRV-1s Front Speaker Screen Replacement
Wat je nodig hebt
  1. Braven BRV-1s Front Speaker Screen Replacement, Front Speaker Screen: stap 1, afbeelding 1 van 2 Braven BRV-1s Front Speaker Screen Replacement, Front Speaker Screen: stap 1, afbeelding 2 van 2
    • Using a 1.5mm hex screwdriver start unscrewing the 0.6mm screws holding down the front replacement screen
    • Repeat the unscrewing process for the other 7 screws
  2. Braven BRV-1s Front Speaker Screen Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic spudger to pry off the front speaker screen
  3. Braven BRV-1s Front Speaker Screen Replacement: stap 3, afbeelding 1 van 1
    • Peel off the front screen using your fingers after using the plastic prying tool/spudger
    • Be careful not to damage the glue underneath the front speaker screen, damaging the glue may cause the device to no longer be waterproof.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 877
