Ga door naar hoofdinhoud
Braven BRV-1M Sub-woofer Cone Replacement
Wat je nodig hebt
  1. Braven BRV-1M Sub-woofer Cone Replacement, Sub-woofer Cone: stap 1, afbeelding 1 van 1
    • To remove the outer rubber casing use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides, found on the bottom part of the device.
  2. Braven BRV-1M Sub-woofer Cone Replacement: stap 2, afbeelding 1 van 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Sub-woofer Cone Replacement: stap 3, afbeelding 1 van 1
    • To remove the hard inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the subwoofer on the top side of the device.
  4. Braven BRV-1M Sub-woofer Cone Replacement: stap 4, afbeelding 1 van 1
    • Carefully lift away the broken sub-woofer plate of the device. Replace with functioning sub-woofer plate.
Conclusie
Erik Oliva
607 Reputatie
6 handleidingen geschreven
USF Tampa, Team S2-G1, Eyestone Spring 2018 Lid van USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 190
