Inleiding
Having a damaged outer casing can allow foreign material to enter the speaker. By following this guide, one can learn how to remove and replace the outer case of the device.
Wat je nodig hebt
To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Where can I buy parts for this speaker? My rear charging door has broken off disabling the ruggedness. Be easier to buy versus build new piece.
