Ga door naar hoofdinhoud
Braven BRV-1M Outer Casing Replacement
Wat je nodig hebt
  1. Braven BRV-1M Outer Casing Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Outer Casing Replacement: stap 2, afbeelding 1 van 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Outer Casing Replacement: stap 3, afbeelding 1 van 1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Outer Casing Replacement: stap 4, afbeelding 1 van 1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Erik Oliva
607 Reputatie
6 handleidingen geschreven
USF Tampa, Team S2-G1, Eyestone Spring 2018 Lid van USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 Leden
Één opmerking
Where can I buy parts for this speaker? My rear charging door has broken off disabling the ruggedness. Be easier to buy versus build new piece.
Michael Harruff - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 635
