Ga door naar hoofdinhoud
Braven BRV-1M Button Register Replacement
Wat je nodig hebt
  1. Braven BRV-1M Button Register Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Button Register Replacement: stap 2, afbeelding 1 van 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Button Register Replacement: stap 3, afbeelding 1 van 1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Button Register Replacement: stap 4, afbeelding 1 van 1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
  5. Braven BRV-1M Button Register Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
  6. Braven BRV-1M Button Register Replacement: stap 6, afbeelding 1 van 1
    • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
  7. Braven BRV-1M Button Register Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
  8. Braven BRV-1M Button Register Replacement: stap 8, afbeelding 1 van 1
    • Once disconnected, carefully remove the motherboard by pulling upwards.
  9. Braven BRV-1M Button Register Replacement, Button Register: stap 9, afbeelding 1 van 1
    • To remove the button registers, unscrew the two Phillips #00 bit type, 6 mm screws found on both sides of the control registers.
  10. Braven BRV-1M Button Register Replacement: stap 10, afbeelding 1 van 1
    • Carefully remove the control registers from the housing of the device.
Conclusie
Erik Oliva
607 Reputatie
6 handleidingen geschreven
USF Tampa, Team S2-G1, Eyestone Spring 2018 Lid van USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 Leden
1Gids Commentaar
Great guide! Do you know the spec/name of the button registers so that I can purchase a new one to replace a dysfunctional one?
Mason McElvain - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 567
