Inleiding
The charging base wire harness is essential to the function of the Braun Series 7 790cc-7 charging base. Many consumers may discard the charging base if it cannot be used to charge and clean the razor. This can be expensive but by replacing a faulty charging harness the razor can be used with the charging base again. With the use of this Replacement Guide, one can easily change the charging base harness if required.
Wat je nodig hebt
Één andere persoon heeft deze handleiding voltooid.
