Inleiding
The removal of the battery is a rather easy process, but very critical when thinking about the use of this razor. Many people will use an electric razor until it dies for the first time, but rather than replacing the battery, they will just buy another electric razor. This is an expensive habit to get into when one can just replace the battery and use the same razor for an extended period of time. With the use of this Replacement Guide, one can easily change the battery in the razor as many times as they would like.
Wat je nodig hebt
Replace the battery with a new 1300 mAh Sanyo (UR18500Y) battery.
Be sure to insert the battery the correct way.
hey namesake thanks for the effort! Is the same true for the 7899cc?
The shaver was working on electricity before I disassemble it. As I couldn't find a new battery I re-assembled is with the old battery but it does not work anymore on electricity.
Is there any trick here?
An excellent step by step instructions…??????????
Very detailed repair instructions.
I will give this a try.
Thanks
27 andere personen hebben deze handleiding voltooid.
27 opmerkingen
Where do you buy the Battery?
For example, on Amazon: https://www.amazon.com/Braun-81377206-RE...
Thank you for the awesome tutorial Alex!
I just wanted to comment that a small flat-head screw driver can be used to remove the 4 screws (under the rubber handle piece) if you don’t have a Torx tool. The screws each have 1 small slot across the head and if you’re careful you can remove and re-install them without too much trouble.
Thanks again for helping to save me a lot of trouble with this Alex… and avoid having to buy a new electric razor!
-jb-
Under Braun there is a reset button, hold in for 4 seconds
What are symptoms of dying battery, other than failure to hold a charge? My Series 7 9595 will run perfectly, until I use the pop-up side trimmer. Then it shuts OFF, with the full battery and Hygiene meter dropping to absolute zero. I open it up and pull the battery…. and suddenly battery charge is “restored.” I’m stumped…
Same question as jclemis
Thanks for the great information, the reset information is also very helpful. I am going to reset it on a full charge. Very easy to change, much better than the ones that had them soldered in.
Have followed all above instructions and shaver works well until the back is replaced then stops working. Blue light comes on but shaver does not start? Can anyone explain why?
Brian H
I have the same problem as Brian H does. I replaced the battery and replaced the back cover, the blue light comes on but it doesn’t turn on. If I take the cover off and hold the motor in with 2 screws, the motor turns on so I’m sure all of the components work. Has anyone else have the same problem? Does anyone have a fix for this problem?
Walt L
I have he same problem as Brian H and Walt L. Came to this site to find the answer. If I find the solution, I’ll come back and post it.
Thanks for the tutorial.
Idiot as I am - I inserted the battery the wrong way.
And now the shaver is dead.
What can I do?
Best regards
Hans, Denmark
My unit would light up after battery replacement, but motor would not operate. I determined that motor assembly contacts were not touching opposing contacts; cover screws were going through square holes in brackets rather than the round holes. To allow motor assembly to push far enough into main body, I removed shaver cartridge to allow better manipulation. Then I opened trimmer unit. This allowed me to push the motor assembly to its correct location and allowed the upper screws to slip thru the round holes in mounting ears to hold motor assembly at correct depth.
Thanks! Unfortunately, the screws on mine are completely corroded… :(
I replaced battery in my Series 7. Would not work. Put the original battery which was still working some back in. Now it won’t charge. The new battery I bought didn’t have the little tips that stick out in the middle of each end. Help!
Great, easy to follow tutorial. It feel so much better to start opening stuff when you realize someone else has already done it, and done it successfully without ruin the gadget (which is the whole point in the first place).
Same question as Mike O from a year ago: is this battery a standard 18650 rechargeable Li-ion?
Maybe someone could kindly post what the correct battery position is rather than just telling us to make sure we put it in the right way.
According to the video, the positive end should be inserted toward the bottom of the shaver.
Installed fully charged battery correctly, 4 sec. reset. Nothing. No charge level or blue light. Disassembled, reassembled several times. Still dead!
Danke. Sehr gute Anleitung. Ich habe sie bei einem BRAUN 750cc-4 erfolgreich angewendet.
