Ga door naar hoofdinhoud
Braun Series 7 790cc-7 Battery Replacement
Wat je nodig hebt
  1. Braun Series 7 790cc-7 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Braun Series 7 790cc-7 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use a spudger to remove the rubber piece on the back of the razor.
  2. Braun Series 7 790cc-7 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a Torx T8 to remove (4) 10 mm screws from housing.
  3. Braun Series 7 790cc-7 Battery Replacement: stap 3, afbeelding 1 van 2 Braun Series 7 790cc-7 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the rear cover from the device.
  4. Braun Series 7 790cc-7 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery from the holster inside the device.
  5. Braun Series 7 790cc-7 Battery Replacement: stap 5, afbeelding 1 van 1
    • Replace the battery with a new 1300 mAh Sanyo (UR18500Y) battery.
    • Be sure to insert the battery the correct way.
Conclusie
27 andere personen hebben deze handleiding voltooid.
Alex Speer
763 Reputatie
1 Handleiding geschreven
IUPUI, Team S3-G6, Harley Fall 2017 Lid van IUPUI, Team S3-G6, Harley Fall 2017
IUPUI-HARLEY-F17S3G6
3 Leden
5 handleidingen geschreven
27 opmerkingen
Any idea on how to remove/replace the drive unit? I bought a new one but the plastic backing is extremely hard to get off.
Chris - Antwoord
Thank you for the awesome tutorial Alex!
I just wanted to comment that a small flat-head screw driver can be used to remove the 4 screws (under the rubber handle piece) if you don’t have a Torx tool. The screws each have 1 small slot across the head and if you’re careful you can remove and re-install them without too much trouble.
Thanks again for helping to save me a lot of trouble with this Alex… and avoid having to buy a new electric razor!
-jb-
arcticassault - Antwoord
How do you reset the battery life indicator on the shaver after replacement?
jclemis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 137
Afgelopen 30 dagen: 682
Altijd: 54,647
