Ga door naar hoofdinhoud
Braun KMM1 Coffe Grinder Disassembly for cleaning
Wat je nodig hebt
  1. Braun KMM1 Coffe Grinder Disassembly for cleaning, Braun KMM1 Coffe Grinder Disassembly for cleaning: stap 1, afbeelding 1 van 1
    • First, remove the coffee powder container
  2. Braun KMM1 Coffe Grinder Disassembly for cleaning: stap 2, afbeelding 1 van 1
    • Remove the cap of the bean container
  3. Braun KMM1 Coffe Grinder Disassembly for cleaning: stap 3, afbeelding 1 van 2 Braun KMM1 Coffe Grinder Disassembly for cleaning: stap 3, afbeelding 2 van 2
    • Now it's time to rotate the bean container anti-clockwise to remove it from the machine
  4. Braun KMM1 Coffe Grinder Disassembly for cleaning: stap 4, afbeelding 1 van 1
    • Here you can see the mill wheel which is now ready to be cleaned
  5. Braun KMM1 Coffe Grinder Disassembly for cleaning: stap 5, afbeelding 1 van 3 Braun KMM1 Coffe Grinder Disassembly for cleaning: stap 5, afbeelding 2 van 3 Braun KMM1 Coffe Grinder Disassembly for cleaning: stap 5, afbeelding 3 van 3
    • Back to the bean container!
    • After a short cleaning action you should be able to loosen this three Philips screws
  6. Braun KMM1 Coffe Grinder Disassembly for cleaning: stap 6, afbeelding 1 van 2 Braun KMM1 Coffe Grinder Disassembly for cleaning: stap 6, afbeelding 2 van 2
    • Now the bean container is completely disassembled and ready for some cleaning work!
Conclusie
16 andere personen hebben deze handleiding voltooid.
Daniel
934 Reputatie
2 handleidingen geschreven
iFixit EU Team Lid van iFixit EU Team
Staff
46 Leden
1.094 handleidingen geschreven
9 opmerkingen
Hi Daniel,
Thanks for the tutorial.
Would you have, by any chance, the usermanual of the grinder?
I’m wondering to what grinding size the numbering is corresponding to.
Many thanks! :)
Best regards,
Greg
freestyle_on_the_moon - Antwoord
I have this same issue! Did you ever find out? Im guessing that the grind size of the KMM1 is the same as the KMM20? So left (where it says mocca)for finest grind, right for the largest grind?
Will Clempson -
Umm.. My bottom burr doesn’t seem to have screws and look like rivits. maybe previous owner stripped the screws :(
Zarni Ko - Antwoord
Mine has something like rivets as well. I used toothpicks and cotton swabs to clean as much as I could,, then had some luck running dried couscous through the grinder. Softer than rice and seemed to pick up the last bits of residue.
Zeke Kossover -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 158
Altijd: 10,628
