Ga door naar hoofdinhoud
Braun Aromaster KF440 one-way valve Replacement
Wat je nodig hebt
  1. Braun Aromaster KF440 one-way valve Replacement, Access the base: stap 1, afbeelding 1 van 1
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 one-way valve Replacement, Remove the nut: stap 2, afbeelding 1 van 1
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 one-way valve Replacement, Remove the cover: stap 3, afbeelding 1 van 1
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
  4. Braun Aromaster KF440 one-way valve Replacement, Locate internal one-way valve: stap 4, afbeelding 1 van 1
    • Locate the one-way valve.
  5. Braun Aromaster KF440 one-way valve Replacement, Pull out valve: stap 5, afbeelding 1 van 1
    • Lift up on the one way valve to snap it out of place. (This shouldn't require much force).
  6. Braun Aromaster KF440 one-way valve Replacement, Push tube off the one-way valve: stap 6, afbeelding 1 van 1
    • Using the larger plastic opening tool, gently push the tubing off of the one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
  7. Braun Aromaster KF440 one-way valve Replacement, Lift valve: stap 7, afbeelding 1 van 1
    • Completely remove one-way valve from the inside of the coffee maker.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Dennis
315 Reputatie
2 handleidingen geschreven
Baylor, Team 8-12, Williams Fall 2014 Lid van Baylor, Team 8-12, Williams Fall 2014
BU-WILLIAMS-F14S8G12
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 3,261
