Ga door naar hoofdinhoud
Boss RC-1 Loop Station-Pedal Battery Replacement
Wat je nodig hebt
  1. Boss RC-1 Loop Station-Pedal Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Push down on the pedal in order to relieve pressure on the thumbscrew.
  2. Boss RC-1 Loop Station-Pedal Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the thumb screw at the bottom of the device.
    • Loosening the thumb screw far enough will also allow the pedal to open.
  3. Boss RC-1 Loop Station-Pedal Battery Replacement: stap 3, afbeelding 1 van 2 Boss RC-1 Loop Station-Pedal Battery Replacement: stap 3, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove the two screws that secure the pedal to the device.
  4. Boss RC-1 Loop Station-Pedal Battery Replacement: stap 4, afbeelding 1 van 1
    • Take the battery out of the device.
  5. Boss RC-1 Loop Station-Pedal Battery Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the snap chord from the battery.
  6. Boss RC-1 Loop Station-Pedal Battery Replacement: stap 6, afbeelding 1 van 1
    • Reassemble the device in the opposite order.
    • When tightening the thumbscrew back in the device, apply force to the pedal first (Do step 1 before step 2).
Conclusie
To check if the batter replacement was successful, plug in a guitar cable into the “Output A” jack. If the red light turns on below the “check” (top of the device), then the looper pedal is working.
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 133
Altijd: 5,621
