Ga door naar hoofdinhoud
Bose Soundlink Revolve Top Circuit Board Replacement
Wat je nodig hebt
  1. Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: stap 1, afbeelding 1 van 2 Bose Soundlink Revolve Top Circuit Board Replacement, Bottom Circuit Board Access: stap 1, afbeelding 2 van 2
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve Top Circuit Board Replacement: stap 2, afbeelding 1 van 3 Bose Soundlink Revolve Top Circuit Board Replacement: stap 2, afbeelding 2 van 3 Bose Soundlink Revolve Top Circuit Board Replacement: stap 2, afbeelding 3 van 3
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve Top Circuit Board Replacement: stap 3, afbeelding 1 van 2 Bose Soundlink Revolve Top Circuit Board Replacement: stap 3, afbeelding 2 van 2
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve Top Circuit Board Replacement: stap 4, afbeelding 1 van 2 Bose Soundlink Revolve Top Circuit Board Replacement: stap 4, afbeelding 2 van 2
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve Top Circuit Board Replacement, Top Circuit Board: stap 5, afbeelding 1 van 1
    • Using your hands, grip and separate the soft plastic and the metal casing away from each other with some small force.
  6. Bose Soundlink Revolve Top Circuit Board Replacement: stap 6, afbeelding 1 van 1
    • Remove the (4) four screws shown around the top of the inside.
    • (2) two of the screws are shown here, the other side will look the same.
  7. Bose Soundlink Revolve Top Circuit Board Replacement: stap 7, afbeelding 1 van 2 Bose Soundlink Revolve Top Circuit Board Replacement: stap 7, afbeelding 2 van 2
    • Pry up and remove the soft plastic casing from the rest of the device.
  8. Bose Soundlink Revolve Top Circuit Board Replacement: stap 8, afbeelding 1 van 2 Bose Soundlink Revolve Top Circuit Board Replacement: stap 8, afbeelding 2 van 2
    • Remove the 3 screws holding down the top circuit board.
  9. Bose Soundlink Revolve Top Circuit Board Replacement: stap 9, afbeelding 1 van 1
    • Lift up and look on the underside of the circuit board.
    • Using the plastic opening tool, pry open the wide clamp keeping a ribbon to the top circuit board. The top circuit board can now freely be removed from the device.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Brian Butner
861 Reputatie
3 handleidingen geschreven
USF Tampa, Team S6-G2, Remmell Fall 2017 Lid van USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 Leden
4 handleidingen geschreven
12 opmerkingen
Hello,
I need to buy the TOP CIRCUIT BOARD … Where Can I buy it or could you sell me one ? Thank you my mail is skelet300@gmail.com
skelet300 - Antwoord
I also need one of these boards and don’t really want to buy a complete used unit to repair mine, copydoc1@aol.com if you know of any resources, thanks in advance.
Jeff Pitt - Antwoord
Same here. My speaker had one circuit replacement on warranty but now need a second replacement and I not willing to pay half the price of a new speaker each a every year. Can you help please ?
My e-mail is fmtbmp@gmail.com
fmpitschieller - Antwoord
Hi, I need to buy the top and bottom circuit board and was wondering the same. Any help with where to purchase these would be appreciated,
Thanks, my email is fayclaybrook28@outlook.com
Fay Claybrook - Antwoord
I am also looking for a top circuit board replacement. Where can I get one. michael@parsche.net
Michael Parsche - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 91
Altijd: 13,220
