Inleiding
If you are experiencing problems with your Soundlink III's functioning such that the device won't turn on or certain buttons won't work, your motherboard may need replacement.
Wat je nodig hebt
Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
Gently peel back the adhesive padding on either side of the inner back panel.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Hi, I have to replace my SLIII motherboard.
The question is. Where can I get one ?
