Ga door naar hoofdinhoud
Bose SoundLink Mini Speakers Replacement
Wat je nodig hebt
  1. Bose SoundLink Mini Speakers Replacement, Battery: stap 1, afbeelding 1 van 1
    • Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
  2. Bose SoundLink Mini Speakers Replacement: stap 2, afbeelding 1 van 2 Bose SoundLink Mini Speakers Replacement: stap 2, afbeelding 2 van 2
    • While holding the cover back, pull straight up on the battery to remove it.
  3. Bose SoundLink Mini Speakers Replacement, Front/Back Protective Grille: stap 3, afbeelding 1 van 1
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  4. Bose SoundLink Mini Speakers Replacement: stap 4, afbeelding 1 van 2 Bose SoundLink Mini Speakers Replacement: stap 4, afbeelding 2 van 2
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  5. Bose SoundLink Mini Speakers Replacement: stap 5, afbeelding 1 van 2 Bose SoundLink Mini Speakers Replacement: stap 5, afbeelding 2 van 2
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  6. Bose SoundLink Mini Speakers Replacement: stap 6, afbeelding 1 van 2 Bose SoundLink Mini Speakers Replacement: stap 6, afbeelding 2 van 2
    • Repeat steps to remove the back grille.
  7. Bose SoundLink Mini Speakers Replacement, Battery Cover: stap 7, afbeelding 1 van 2 Bose SoundLink Mini Speakers Replacement, Battery Cover: stap 7, afbeelding 2 van 2
    • Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
  8. Bose SoundLink Mini Speakers Replacement: stap 8, afbeelding 1 van 2 Bose SoundLink Mini Speakers Replacement: stap 8, afbeelding 2 van 2
    • Remove the circuit board by pushing it with your index finger in the direction shown while using a nylon or metal spudger to lift it up and out of place.
  9. Bose SoundLink Mini Speakers Replacement: stap 9, afbeelding 1 van 2 Bose SoundLink Mini Speakers Replacement: stap 9, afbeelding 2 van 2
    • Carefully pull on the battery cover until the rubber tab slides out of the aluminum casing.
  10. Bose SoundLink Mini Speakers Replacement, Button Switch Circuit Board: stap 10, afbeelding 1 van 1
    • Remove the sponge (save for later replacement) and gently flip the black tab 90 degrees to release the connectors grip on the ribbon cable. Remove the ribbon cable from the connector.
    • The black tab must be flipped up in order to reinsert the ribbon cable on reassembly.
  11. Bose SoundLink Mini Speakers Replacement: stap 11, afbeelding 1 van 3 Bose SoundLink Mini Speakers Replacement: stap 11, afbeelding 2 van 3 Bose SoundLink Mini Speakers Replacement: stap 11, afbeelding 3 van 3
    • Use a Metal Spudger to pry up the plastic divider.
  12. Bose SoundLink Mini Speakers Replacement: stap 12, afbeelding 1 van 2 Bose SoundLink Mini Speakers Replacement: stap 12, afbeelding 2 van 2
    • When removing the plastic divider be careful not to damage the wire strip sliding through it.
  13. Bose SoundLink Mini Speakers Replacement: stap 13, afbeelding 1 van 2 Bose SoundLink Mini Speakers Replacement: stap 13, afbeelding 2 van 2
    • Reach through the battery compartment hole and unplug the power strip shown.
  14. Bose SoundLink Mini Speakers Replacement: stap 14, afbeelding 1 van 3 Bose SoundLink Mini Speakers Replacement: stap 14, afbeelding 2 van 3 Bose SoundLink Mini Speakers Replacement: stap 14, afbeelding 3 van 3
    • Remove both circuit boards by wiggling them up and out of the casing.
    • Unplug the speaker wires connected and fully remove both circuit boards.
    • When unplugging the speaker wires, squeeze the white connector piece to release the wires.
  15. Bose SoundLink Mini Speakers Replacement: stap 15, afbeelding 1 van 2 Bose SoundLink Mini Speakers Replacement: stap 15, afbeelding 2 van 2
    • Unhook the speaker wires clipped onto the button switch circuit board.
  16. Bose SoundLink Mini Speakers Replacement: stap 16, afbeelding 1 van 3 Bose SoundLink Mini Speakers Replacement: stap 16, afbeelding 2 van 3 Bose SoundLink Mini Speakers Replacement: stap 16, afbeelding 3 van 3
    • Use a nylon or metal spudger to slightly lift up on the button switch circuit board.
    • Pull the button switch circuit board straight out from the casing.
  17. Bose SoundLink Mini Speakers Replacement, Speakers: stap 17, afbeelding 1 van 2 Bose SoundLink Mini Speakers Replacement, Speakers: stap 17, afbeelding 2 van 2
    • Remove the eight 9.0 mm screws using the T8 Torx Screwdriver.
  18. Bose SoundLink Mini Speakers Replacement: stap 18, afbeelding 1 van 3 Bose SoundLink Mini Speakers Replacement: stap 18, afbeelding 2 van 3 Bose SoundLink Mini Speakers Replacement: stap 18, afbeelding 3 van 3
    • Using a nylon or metal spudger, pry up the plastic divider and remove it.
  19. Bose SoundLink Mini Speakers Replacement: stap 19, afbeelding 1 van 3 Bose SoundLink Mini Speakers Replacement: stap 19, afbeelding 2 van 3 Bose SoundLink Mini Speakers Replacement: stap 19, afbeelding 3 van 3
    • Gently lift the speakers up and out of the casing.
Conclusie
18 andere personen hebben deze handleiding voltooid.
Jordan Smith
895 Reputatie
4 handleidingen geschreven
Cal Poly, Team 1-23, Maness Fall 2015 Lid van Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 Leden
21 handleidingen geschreven
16 opmerkingen
This is great! Well done! Thank you. I dropped mine and there's not any sound now. What would you think happened and where should i start?
[deleted] - Antwoord
Perhaps open it up and then use a multimeter or some other speakers to see if you're getting any output from the amplifier? Sometimes the speaker drivers are damaged by dropping.
Larry Chen -
Do you know the part number for the speaker or where to buy it ? After a trip to the beach I now have a cracking sound in one of the speakers.
Thanks for the help
Javier Sanchez - Antwoord
Hi,
Where can i buy genuine Bose replacement speakers for the Soundlink?
Scott - Antwoord
Do you know if the the other speakers were passive radiators or powered subwoofers? Bose claims that the are subwoofers but I'm skeptical
Thomas Catanzarita - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 74
Afgelopen 30 dagen: 391
Altijd: 43,927
