Ga door naar hoofdinhoud
Bose SoundLink Mini Front/Back Protective Grille Replacement
Wat je nodig hebt
  1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: stap 1, afbeelding 1 van 1
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  2. Bose SoundLink Mini Front/Back Protective Grille Replacement: stap 2, afbeelding 1 van 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: stap 2, afbeelding 2 van 2
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. Bose SoundLink Mini Front/Back Protective Grille Replacement: stap 3, afbeelding 1 van 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: stap 3, afbeelding 2 van 2
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Bose SoundLink Mini Front/Back Protective Grille Replacement: stap 4, afbeelding 1 van 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: stap 4, afbeelding 2 van 2
    • Repeat steps to remove the back grille.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Jordan Smith
895 Reputatie
4 handleidingen geschreven
Cal Poly, Team 1-23, Maness Fall 2015 Lid van Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 Leden
21 handleidingen geschreven
6 opmerkingen
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - Antwoord
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - Antwoord
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Ronald Roden Jr - Antwoord
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 99
Altijd: 12,772
