Ga door naar hoofdinhoud
Bose SoundLink Color Button Pad Replacement
Wat je nodig hebt
  1. Bose SoundLink Color  Button Pad Replacement, Outer Casing: stap 1, afbeelding 1 van 2 Bose SoundLink Color  Button Pad Replacement, Outer Casing: stap 1, afbeelding 2 van 2
    • Four round, plastic plugs are located on the back of the device.
    • Using a metal spudger, carefully pry up the plastic covers.
    • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
  2. Bose SoundLink Color  Button Pad Replacement: stap 2, afbeelding 1 van 2 Bose SoundLink Color  Button Pad Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
    • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
  3. Bose SoundLink Color  Button Pad Replacement: stap 3, afbeelding 1 van 2 Bose SoundLink Color  Button Pad Replacement: stap 3, afbeelding 2 van 2
    • Carefully open up the casing.
    • The top button pad may need to be re-glued upon installing the new casing.
  4. Bose SoundLink Color  Button Pad Replacement, Button Pad: stap 4, afbeelding 1 van 2 Bose SoundLink Color  Button Pad Replacement, Button Pad: stap 4, afbeelding 2 van 2
    • Lift up the retaining flap on the button cable ZIF connector.
    • Pull the button cable straight out of the connector.
  5. Bose SoundLink Color  Button Pad Replacement: stap 5, afbeelding 1 van 2 Bose SoundLink Color  Button Pad Replacement: stap 5, afbeelding 2 van 2
    • Carefully pull the ribbon cable through the rubber gasket that runs around the device.
  6. Bose SoundLink Color  Button Pad Replacement: stap 6, afbeelding 1 van 1
    • To remove the old rubber button pad, carefully peel it off of the blue casing.
Conclusie
To reassemble your device, follow these instructions in reverse order, starting from Step 6.
8 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Great guide, and I think I can manage this. But, where can I get the Replacement Bose SoundLink Color Button Pad??
Fred
Fred Fish - Antwoord
I’m wondering the same thing. Where do you get the replacement Bose Soundlink Color button pad? We just bought a new charger because we thought that was the problem. But that didn’t make any difference. We still can’t turn the speaker on!
Lynn Wilson - Antwoord
I got the bose soundlink color button panel only with bose India authorised service center in South Mumbai . That cost me in Indian RS. 2360. Including approx $35 USD.
nrirehan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 42
Altijd: 10,387
