Inleiding
The explanations will detail how to remove the bottom plate, revealing the logic board as well as removing the proper attachments and screws. The proper knowledge of how to use a soldering iron is needed when dealing with this component. The following steps will help you find success in replacing the logic board, if needed.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Desoldering Pump$3.99
Using a hot soldering iron and either a solder sucker or de-soldering wick, remove the solder from the 6 wires highlighted on the photo in red.
To reassemble your device, follow these instructions in reverse order. With proper execution of these steps, you will be able to replace your logic board and enjoy the sound of your SoundDock XT.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Hi, one question, where can i buy the replacement logic board?
