Ga door naar hoofdinhoud
Bose Solo 5 Sound Bar Remote Batteries Replacement
  1. Bose Solo 5 Sound Bar Remote Batteries Replacement, Remote Batteries: stap 1, afbeelding 1 van 3 Bose Solo 5 Sound Bar Remote Batteries Replacement, Remote Batteries: stap 1, afbeelding 2 van 3 Bose Solo 5 Sound Bar Remote Batteries Replacement, Remote Batteries: stap 1, afbeelding 3 van 3
    • Open the battery compartment cover on the back of the remote by applying pressure with fingers and sliding downward.
  2. Bose Solo 5 Sound Bar Remote Batteries Replacement: stap 2, afbeelding 1 van 1
    • Remove both AA batteries carefully.
  3. Bose Solo 5 Sound Bar Remote Batteries Replacement: stap 3, afbeelding 1 van 1
    • Look for any battery acid corrosion in the wells and clean with a cotton swab or a dull pointed tool to remove the residue.
    • Insert two AA (IEC-LR6) 1.5V batteries or the equivalent.
    • Match the + and – symbols on the batteries with + and – markings inside the compartment.
  4. Bose Solo 5 Sound Bar Remote Batteries Replacement: stap 4, afbeelding 1 van 3 Bose Solo 5 Sound Bar Remote Batteries Replacement: stap 4, afbeelding 2 van 3 Bose Solo 5 Sound Bar Remote Batteries Replacement: stap 4, afbeelding 3 van 3
    • To reassemble your device, place the cover back over the batteries by lining up the teeth and sliding upward until you hear a click.
Conclusie
We hope this guide was useful to you! Replacing your Bose Solo 5 Soundbar remote batteries should be quick and easy!
Één andere persoon heeft deze handleiding voltooid.
Emma
500 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 36
Altijd: 4,560
