Ga door naar hoofdinhoud
Bose Solo 5 Sound Bar Control Panel Replacement
Wat je nodig hebt
  1. Bose Solo 5 Sound Bar Control Panel Replacement, Control Panel: stap 1, afbeelding 1 van 1
    • Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
  2. Bose Solo 5 Sound Bar Control Panel Replacement: stap 2, afbeelding 1 van 2 Bose Solo 5 Sound Bar Control Panel Replacement: stap 2, afbeelding 2 van 2
    • Remove the five 18.25mm screws with the Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Control Panel Replacement: stap 3, afbeelding 1 van 1
    • Remove the gold plates snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Control Panel Replacement: stap 4, afbeelding 1 van 1
    • Using the plastic opening tool, lift the circuit board up and remove from housing.
  5. Bose Solo 5 Sound Bar Control Panel Replacement: stap 5, afbeelding 1 van 2 Bose Solo 5 Sound Bar Control Panel Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Emma
500 Reputatie
3 handleidingen geschreven
5 opmerkingen
Does anyone know where to buy a replacement logic board? I’ve been searching for a while now, no dice.
Tyler Barney - Antwoord
hallo und wo bekomme ich das Ersatzteil die Platiene 73252 Delta 3
APP TISCHNER - Antwoord
Has anyone had any luck finding the same board. Im looking.
ka.wells - Antwoord
I know how to open it. What I don't know is where to buy one.
szanti - Antwoord
If anyone was able to find the board, it wuold be great to know where did you find it. Looking for this board during months...
Juan Ramirez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 114
Altijd: 12,816
