Ga door naar hoofdinhoud
Bose QuietComfort 25 Battery Replacement
  1. Bose QuietComfort 25 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Bose QuietComfort 25 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the side designation in the interior of the earpiece.
    • The battery compartment is located on the top of the right-side earpiece, accessible via the latched door.
  2. Bose QuietComfort 25 Battery Replacement: stap 2, afbeelding 1 van 2 Bose QuietComfort 25 Battery Replacement: stap 2, afbeelding 2 van 2
    • Do not allow battery corrosion to come into contact with your skin or eyes.
    • Sometimes, batteries or the terminals they come into contact with can become corroded. Corrosion will appear as chalky-white or green.
    • If the compartment is not clean--coated with debris or corroded--use a cotton swab to carefully remove debris or corrosion from the terminal corrosion.
  3. Bose QuietComfort 25 Battery Replacement: stap 3, afbeelding 1 van 1
    • Insert a new battery.
    • Make sure that the polarity of the battery is aligned correctly to the diagram on the inside of the cartridge.
Conclusie
When finished with this guide process, the Bose QuietComfort 25 should be able to be played with the functioning noise-cancelling feature.
9 andere personen hebben deze handleiding voltooid.
Één opmerking
Are there any option for replacing the latch together with the spring?
I wanted to replace these after a battery leak, but I'm unable to find any sources for the part needed unless you want to buy a full set of headphones from some one else.
Erik - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 153
Altijd: 12,391
