Ga door naar hoofdinhoud
Boombotix Boombot Mini Speaker Replacement
Wat je nodig hebt
  1. Boombotix Boombot Mini Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 Boombotix Boombot Mini Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 Boombotix Boombot Mini Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Twist the front panel of the speaker to the left.
    • Do not try to pry or pop off the front panel.
  2. Boombotix Boombot Mini Speaker Replacement: stap 2, afbeelding 1 van 3 Boombotix Boombot Mini Speaker Replacement: stap 2, afbeelding 2 van 3 Boombotix Boombot Mini Speaker Replacement: stap 2, afbeelding 3 van 3
    • Take out the four screws, then remove the panel that contains the speaker.
  3. Boombotix Boombot Mini Speaker Replacement: stap 3, afbeelding 1 van 3 Boombotix Boombot Mini Speaker Replacement: stap 3, afbeelding 2 van 3 Boombotix Boombot Mini Speaker Replacement: stap 3, afbeelding 3 van 3
    • Take the speaker off of the base.
    • Expose the motherboard and place the speaker next to it.
    • Be careful not to tangle or damage the wires connecting the speaker.
    • This panel will be harder to get off. Use something small such as a card to creat a lip for leverage.
  4. Boombotix Boombot Mini Speaker Replacement: stap 4, afbeelding 1 van 1
    • Find the connection of the speaker by following the wires.
    • Do not damage the battery. Make sure not to use any metal object to poke around in the device because of possible shock.
  5. Boombotix Boombot Mini Speaker Replacement: stap 5, afbeelding 1 van 2 Boombotix Boombot Mini Speaker Replacement: stap 5, afbeelding 2 van 2
    • Now that you have found the wire connection to the motherboard, disconnect it.
    • Pull the wire straight out.
  6. Boombotix Boombot Mini Speaker Replacement: stap 6, afbeelding 1 van 1
    • Connect the white plug of the new speaker to the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,478
