Ga door naar hoofdinhoud
Bonaok Q37 Battery Replacement
Wat je nodig hebt
  1. Bonaok Q37 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power down the microphone before proceeding to the next step.
  2. Bonaok Q37 Battery Replacement: stap 2, afbeelding 1 van 2 Bonaok Q37 Battery Replacement: stap 2, afbeelding 2 van 2
    • Hold the handle with your right hand and unscrew towards you.
    • Once the cover is unscrewed completely, remove the handle cover.
  3. Bonaok Q37 Battery Replacement: stap 3, afbeelding 1 van 2 Bonaok Q37 Battery Replacement: stap 3, afbeelding 2 van 2
    • Lift up the side edges of the "Caution" sticker to unseal the battery cover.
    • If the battery compartment cover is not sealed with a caution sticker, proceed to Step 4.
  4. Bonaok Q37 Battery Replacement: stap 4, afbeelding 1 van 2 Bonaok Q37 Battery Replacement: stap 4, afbeelding 2 van 2
    • Use a pair of tweezers to push the cover towards the left.
    • Lift up the cover to remove it from the microphone.
  5. Bonaok Q37 Battery Replacement: stap 5, afbeelding 1 van 3 Bonaok Q37 Battery Replacement: stap 5, afbeelding 2 van 3 Bonaok Q37 Battery Replacement: stap 5, afbeelding 3 van 3
    • Push the battery towards the left and lift it up from the (+) side.
    • Remove the battery from the compartment.
  6. Bonaok Q37 Battery Replacement: stap 6, afbeelding 1 van 1
    • Insert a new battery into the compartment.
    • Make sure you insert the (-) end first, then push towards the left to make room for the whole battery to be pushed into the compartment.
  7. Bonaok Q37 Battery Replacement: stap 7, afbeelding 1 van 3 Bonaok Q37 Battery Replacement: stap 7, afbeelding 2 van 3 Bonaok Q37 Battery Replacement: stap 7, afbeelding 3 van 3
    • Close the lid and seal back with the caution sticker.
    • Screw the handle back on by twisting it away from you.
  8. Bonaok Q37 Battery Replacement: stap 8, afbeelding 1 van 1
    • Turn the power on and make sure the operating light is blue.
Conclusie
Please charge the device completely before use.
Han Sol Lee
157 Reputatie
1 Handleiding geschreven
4 opmerkingen
What kind of battery?
Carmen Veguilla - Antwoord
Which type of battery? I looked on Amazon but can't find it. Must be age related problem, too old for new tech. 😊
Where can I buy replacement battery
Lee Fisher - Antwoord
NUMBER 18650 3.7volt lithium-ion rechargeable, available online everywhere BUT cannot ship with most carriers so delivery charge is expensive
William Row - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 60
Altijd: 1,528
