Ga door naar hoofdinhoud
Blu Studio Selfie Battery Replacement
Wat je nodig hebt
  1. Blu Studio Selfie Battery Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Battery Replacement: stap 2, afbeelding 1 van 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. Blu Studio Selfie Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Blu Studio Selfie Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stacy Kam
630 Reputatie
5 handleidingen geschreven
USF Tampa, Team 10-1, Remmell Spring 2016 Lid van USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 9
Altijd: 1,324
