Ga door naar hoofdinhoud
Inleiding
In this guide you'll be opening the back panel of your Blu Studio, this is the first step you'll take whenever you replace or add internal parts.
If you don't have any fingernails you may want to use the plastic prying tools.
Onderdelen
Geen onderdelen opgegeven.
  1. Begin by making sure your Blu Studio is turned off.
    • Begin by making sure your Blu Studio is turned off.
  2. To begin the removal of your back panel, first locate the lift tab on the bottom-right corner. To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed. Your rear panel should be placed nearby and in a safe location until you are finished with your task.
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Erik reinbolt
1.536 Reputatie
3 handleidingen geschreven
USF Tampa, Team 9-1, Blackwell Fall 2014 Lid van USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 Leden
8 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,101
