Ga door naar hoofdinhoud
Inleiding
Since the rear facing camera is exposed to the elements, it can often be vulnerable to accidental breaking or cracking. This guide will describe how to disassemble the phone in order to repair it.
Onderdelen
Geen onderdelen opgegeven.
  1. In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Place your finger in the small notch on the left side of the charging port (facing from the back). Once your finger is in the notch, pull the back case towards yourself to remove it. Once your finger is in the notch, pull the back case towards yourself to remove it.
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it. Insert your finger into the notch near the lower left of the battery, apply pressure and lift up. Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. The speaker is located behind the inner back case.  Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws. Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom. Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Use the Spudger to pop the inner back casing off.  Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case. Pick up the inner back case and flip it over. Pick up the inner back case and flip it over.
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. The rear camera is located in the center of the motherboard . It is connected by a ribbon wire / prong system. Use tweezers to gently pop off the prong system, by pulling upwards on the black cap piece connected to the motherboard from the ribbon wire. Use the Tweezers to pull the camera out of the housing.
    • The rear camera is located in the center of the motherboard . It is connected by a ribbon wire / prong system.
    • Use tweezers to gently pop off the prong system, by pulling upwards on the black cap piece connected to the motherboard from the ribbon wire.
    • Use the Tweezers to pull the camera out of the housing.
    • When removing the back camera be careful not to scratch the lens, unless you are throwing it out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cody Dyl
783 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 4-8, Miles Fall 2014 Lid van UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,447
