Ga door naar hoofdinhoud
Blu Studio 5.5 S Battery Replacement
  1. Blu Studio 5.5 S Battery Replacement, Back Casing: stap 1, afbeelding 1 van 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Battery Replacement, Applying Pressure: stap 2, afbeelding 1 van 3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: stap 2, afbeelding 2 van 3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: stap 2, afbeelding 3 van 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Blu Studio 5.5 S Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Blu Studio 5.5 S Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Cody Dyl
804 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 4-8, Miles Fall 2014 Lid van UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 6,137
