Ga door naar hoofdinhoud
Blu L120 MicroSD Card Replacement
Wat je nodig hebt
  1. Blu L120 MicroSD Card Replacement, Adding additional storage: stap 1, afbeelding 1 van 2 Blu L120 MicroSD Card Replacement, Adding additional storage: stap 1, afbeelding 2 van 2
    • Turn off the device, and remove the back cover. Start on the notch above the charging port and lift cover up and gently work around the phone until the back cover is off.
    • Remove the battery.
  2. Blu L120 MicroSD Card Replacement, Adding additional storage: stap 2, afbeelding 1 van 2 Blu L120 MicroSD Card Replacement, Adding additional storage: stap 2, afbeelding 2 van 2
    • Insert the media card into the phone. Maximum 32gb micro SD.
    • Reinstall the battery and back cover, and power on your device. Success............. you just added more storage to your phone.
Conclusie
Julio
695 Reputatie
6 handleidingen geschreven
Gateway, Team 1-5, Johnson Fall 2014 Lid van Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 188
