Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
  1. Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
    • Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
  2. Use one hand to pull the cover up, and the other hand to hold the phone down.
    • Use one hand to pull the cover up, and the other hand to hold the phone down.
  3. Pull the battery up from the lower left corner.
    • Pull the battery up from the lower left corner.
  4. Now, you can put the new battery in, then replace the cover.
    • Now, you can put the new battery in, then replace the cover.
Conclusie
Julio
695 Reputatie
6 handleidingen geschreven
Gateway, Team 1-5, Johnson Fall 2014 Lid van Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 493
