Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
If you need to replace your BLU GRAND M2 display screen, this guide will show you how to do so in six easy steps. In this guide, you will be removing the back panel, loosening screws, removing the motherboard , and removing the screen.
Wat je nodig hebt
Before beginning the guide, be sure that this replacement guide addresses your specific problem.
Locate the two Torx screws at the bottom of the phone and remove them.
Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
Disconnect the two remaining connectors shown in figure 3.
Using the suction tool, slowly pull out the display screen shown in figure 1.
Use the pry tool to completely detach the display screen from the phone.
When the display is removed, attach your new screen.
After applying the new screen, use the steps in reverse order to reassemble the phone.
