Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
If you need to replace your BLU GRAND M2 display screen, this guide will show you how to do so in six easy steps. In this guide, you will be removing the back panel, loosening screws, removing the motherboard , and removing the screen.
  1. Before beginning the guide, be sure that this replacement guide addresses your specific problem. Locate the two Torx screws at the bottom of the phone and remove them.
    • Before beginning the guide, be sure that this replacement guide addresses your specific problem.
    • Locate the two Torx screws at the bottom of the phone and remove them.
  2. Use the pry tool to wedge between the phone's frame and the back plate.
    • Use the pry tool to wedge between the phone's frame and the back plate.
    • Carefully remove the back plate using the suction tool.
    • Be careful not to damage the phone display and/or the inside components while using the pry tool and the suction tool.
  3. Once the back panel is removed, locate the connector of the display shown in figure 1  on the motherboard side. There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it. Disconnect the two remaining connectors shown in figure 3.
    • Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
    • There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
    • Disconnect the two remaining connectors shown in figure 3.
  4. After removing the connectors, locate the six Phillips screws on the motherboard side and remove them. After removing the six Phillips screws, remove the motherboard piece.
    • After removing the connectors, locate the six Phillips screws on the motherboard side and remove them.
    • After removing the six Phillips screws, remove the motherboard piece.
  5. Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
    • Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
    • Heat up the iOpener from the iFixit kit for 30 seconds in a microwave and apply it on top of the screen to loosen the phone's adhesive.
    • The iOpener can be hot once it is microwaved. Make sure to wear gloves and other safety equipment to prevent any burns.
  6. Using the suction tool, slowly pull out the display screen shown in figure 1. Use the pry tool to completely detach the display screen from the phone. When the display is removed, attach your new screen.
    • Using the suction tool, slowly pull out the display screen shown in figure 1.
    • Use the pry tool to completely detach the display screen from the phone.
    • When the display is removed, attach your new screen.
    • After applying the new screen, use the steps in reverse order to reassemble the phone.
Conclusie
Christopher
187 Reputatie
1 Handleiding geschreven
Gateway, Team S1-G3, Luster Fall 2018 Lid van Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Leden
4 handleidingen geschreven
Één commentaar
What type of torx screwdriver did you use?
npyles86 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 36
Altijd: 1,173
