Ga door naar hoofdinhoud
Blu Grand M2 Charging Port Assembly Replacement
Wat je nodig hebt
  1. Blu Grand M2 Charging Port Assembly Replacement, Charging Port Assembly: stap 1, afbeelding 1 van 1
    • Remove the screws with the T2 Torx screwdriver.
    • Place screws off to the side.
  2. Blu Grand M2 Charging Port Assembly Replacement: stap 2, afbeelding 1 van 2 Blu Grand M2 Charging Port Assembly Replacement: stap 2, afbeelding 2 van 2
    • Once the Torx screws have been removed, use a pry tool and a suction tool to remove the back plate.
    • Using the T2 Torx screwdriver, remove the six Torx screws on the motherboard.
    • Make sure to disconnect all other connections from the camera.
  3. Blu Grand M2 Charging Port Assembly Replacement: stap 3, afbeelding 1 van 1
    • Carefully pry the motherboard assembly from the phone.
    • The charging port assembly is soldered to the motherboard piece. Remove the port with a soldering iron.
    • Once you have removed the faulty port, replace it with the new port. Attach the new charging port with the soldering iron.
    • After installing the new port, repeat the steps in reverse order to reassemble the phone.
    • How to Solder and Desolder Connections
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Richard Hills
150 Reputatie
1 Handleiding geschreven
Gateway, Team S1-G3, Luster Fall 2018 Lid van Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 489
