Ga door naar hoofdinhoud
Blu Grand M2 Power Button Replacement
Wat je nodig hebt
  1. Blu Grand M2  Power Button Replacement, Power Button: stap 1, afbeelding 1 van 1
    • Using a T2 Torx Screwdriver, remove the two screws from the bottom edge of the phone.
  2. Blu Grand M2  Power Button Replacement: stap 2, afbeelding 1 van 2 Blu Grand M2  Power Button Replacement: stap 2, afbeelding 2 van 2
    • Apply the suction tool to the back panel near the bottom edge.
    • Carefully slide the device pick between the back panel and bottom edge.
    • Insert the opening tool into the gap created by the device pick.
    • While holding the suction tool, use the opening tool to gently pry the back panel off.
    • Be Cautious to not damage the phone display and or the inside components while using the pry tool and suction tool.
  3. Blu Grand M2  Power Button Replacement: stap 3, afbeelding 1 van 1
    • Take the end of the opening tool and push the old power button out of its socket.
    • Remove the old power button.
  4. Blu Grand M2  Power Button Replacement: stap 4, afbeelding 1 van 1
    • Place the new BLU Grand M2 power button in the socket.
Conclusie
Alan Rodriguez
311 Reputatie
2 handleidingen geschreven
Gateway, Team S1-G3, Luster Fall 2018 Lid van Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Leden
4 handleidingen geschreven
1Gids Commentaar
Don’t forget to remove the SIM card
Jonathan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 485
