Ga door naar hoofdinhoud
Blu Grand M Speaker Replacement
Wat je nodig hebt
  1. Blu Grand M Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Blu Grand M Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Speaker Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Speaker Replacement: stap 3, afbeelding 1 van 3 Blu Grand M Speaker Replacement: stap 3, afbeelding 2 van 3 Blu Grand M Speaker Replacement: stap 3, afbeelding 3 van 3
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Speaker Replacement: stap 4, afbeelding 1 van 2 Blu Grand M Speaker Replacement: stap 4, afbeelding 2 van 2
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Speaker Replacement, Speaker: stap 5, afbeelding 1 van 2 Blu Grand M Speaker Replacement, Speaker: stap 5, afbeelding 2 van 2
    • Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
    • Remove the 4.0mm screw with a Phillips #000 screwdriver.
    • Using the blue plastic opening tool, remove the exterior cover.
  6. Blu Grand M Speaker Replacement: stap 6, afbeelding 1 van 3 Blu Grand M Speaker Replacement: stap 6, afbeelding 2 van 3 Blu Grand M Speaker Replacement: stap 6, afbeelding 3 van 3
    • Use a Phillips #000 screwdriver to remove each of the four 1.5mm screws.
    • Use a Phillips #000 screwdriver to remove each of the three 3.0mm screws.
    • Use the plastic opening tool to remove the speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cameron Retzlaff
608 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 117
