Ga door naar hoofdinhoud
Blu Grand M Display Replacement
Wat je nodig hebt
  1. Blu Grand M Display Replacement, Display: stap 1, afbeelding 1 van 1
    • Trace the outer black edge of the phone screen in a continuous circle with a hairdryer or heat gun to melt the adhesive.
    • Melting the adhesive can take between 2-3 minutes.
  2. Blu Grand M Display Replacement: stap 2, afbeelding 1 van 3 Blu Grand M Display Replacement: stap 2, afbeelding 2 van 3 Blu Grand M Display Replacement: stap 2, afbeelding 3 van 3
    • Insert an opening pick between the screen and the raised black plastic frame.
    • The black plastic frame is located inside and above the phone's silvery outer metal frame.
    • Insert the flat blade of a nylon halberd spudger between the screen and the black plastic frame.
    • Pull the spudger blade through the adhesive around the circumference of the screen.
  3. Blu Grand M Display Replacement: stap 3, afbeelding 1 van 3 Blu Grand M Display Replacement: stap 3, afbeelding 2 van 3 Blu Grand M Display Replacement: stap 3, afbeelding 3 van 3
    • Apply the suction cup to the phone screen, pressing lightly on the suction cup to remove air and form a tight seal.
    • The adhesive may have cooled from the time since step 1 and rebonded to the phone screen. Reheat the adhesive if necessary to return to a liquid state.
    • Pull on the handle to lift the screen free from the device.
Eindstreep
Liam Rollins
253 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 238
