Ga door naar hoofdinhoud
Blu Dash 5.0 Dual SIM Battery Replacement
Wat je nodig hebt
  1. Blu Dash 5.0 Dual SIM Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
  2. Blu Dash 5.0 Dual SIM Battery Replacement: stap 2, afbeelding 1 van 1
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Dashaya Toney
876 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-7, Miles Fall 2014 Lid van UMass Dartmouth, Team 4-7, Miles Fall 2014
UMASSD-MILES-F14S4G7
3 Leden
Één opmerking
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 4,058
