Ga door naar hoofdinhoud
Blu Dash 5.0 Dual SIM Back Camera Replacement
Wat je nodig hebt
  1. Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: stap 1, afbeelding 1 van 2 Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: stap 1, afbeelding 2 van 2
    • Make sure device is disconnected and turned off.
    • Locate the groove on the bottom left corner of the back of the phone.
    • Insert the plastic opening tool into the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Back Camera Replacement: stap 2, afbeelding 1 van 1
    • Pry the battery out using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Back Camera Replacement: stap 3, afbeelding 1 van 1
    • Remove the 12 screws on the back panel using a J000 screwdriver.
    • Red circles correspond to the screw holes holding 3.5 mm length Phillips screws.
    • Orange circles correspond to the screw holes holding 2.5 mm length Phillips screws.
  4. Blu Dash 5.0 Dual SIM Back Camera Replacement: stap 4, afbeelding 1 van 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: stap 4, afbeelding 2 van 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: stap 4, afbeelding 3 van 3
    • Peel off the back panel with your hand.
    • Remove the back panel slowly to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Back Camera Replacement: stap 5, afbeelding 1 van 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: stap 5, afbeelding 2 van 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Flip up the ZIF flap using the spudger.
    • Gently remove the ribbon cable with tweezers.
    • The ribbon cable is sensitve and needs to be removed carefully to insure its integrity.
    • Remove the back camera using tweezers.
Conclusie
Mukish Kumar Munyady
201 Reputatie
2 handleidingen geschreven
IUPUI, Team 1-1, Baechle Spring 2017 Lid van IUPUI, Team 1-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G1
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 378
