Wat je nodig hebt
It has 2 lights on top and no power switch.
It was seemingly stuck in cleaning mode. I had constant blinking. if i held them both in for 5 seconds, it would go into cleaning mode.
If I did the three seconds, it just blinked like it acknowledged my input but it made no difference. Somewhere it said, turn off the power and press lungo for 5 seconds. No power switch on mine.
I unplugged it for 10ish. Pressed the lungo for 10ish seconds with it unplugged. Im guessing maybe that was to clear the capacitors? Not an electrical guy, but I have had to do that on computers to help reset things.
I plugged it in while holding the lungo button still and waited for 6 more seconds. It seemed to response and started to heat up normally. I hope this helps someone!
Één opmerking
Symptoms: Blinking lights: blink-off-double blink sequence.
Mark guide help me to fix ANOTHER issue: Same model with power switch. A friend gave me after years without use.
Push 3 sec both buttons does nothing.
Push buttons like Mark doen't help
Then I tried not with the LUNGO button but with the short button and noticed this one checks the pump! Switch on with the short button pressed and starta to pump...
As I heve repaired some other kf machines I noticed the pump was working but no water pumped, so the pump was unprimed. I keep trying, the the sound changed and the pump started to work again.
Machine fully repaired without unsecrewing... just "understanding" it.
