Ga door naar hoofdinhoud
Blackberry Storm 9530 SIM Card Replacement
Wat je nodig hebt
  1. Blackberry Storm 9530 SIM Card Replacement, Back Cover Removal: stap 1, afbeelding 1 van 3 Blackberry Storm 9530 SIM Card Replacement, Back Cover Removal: stap 1, afbeelding 2 van 3 Blackberry Storm 9530 SIM Card Replacement, Back Cover Removal: stap 1, afbeelding 3 van 3
    • Locate the two switches toward the bottom corners of the device's back cover.
    • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
    • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
  2. Blackberry Storm 9530 SIM Card Replacement: stap 2, afbeelding 1 van 1
    • Identify that the battery is visible once the back cover has been removed, and locate the battery in the rectangular-shaped top half of the device.
    • Pry apart the battery and back of the device using the flat end of your spudger tool or using your finger if you do not have a spudger.
    • Your battery has a specific orientation resembling a horizontal rectangle. Make sure the gold colored leads are aligned with the gold colored strips on your battery before reassembling.
  3. Blackberry Storm 9530 SIM Card Replacement, SIM Card: stap 3, afbeelding 1 van 1
    • Locate the SIM card once the battery has been removed. The SIM card is typically located in the center of the phone, and it is secured by a metal tray.
  4. Blackberry Storm 9530 SIM Card Replacement: stap 4, afbeelding 1 van 1
    • Remove the SIM card carefully by sliding it upwards out of the metal tray. No tools are needed for this step.
    • Your SIM card has a specific orientation to follow when it is replaced. Make sure the gold colored leads are aligned with the gold colored strips in the SIM card tray before reassembling.
Conclusie
melanie lim
607 Reputatie
6 handleidingen geschreven
Cal Poly, Team 9-16, Regan Spring 2014 Lid van Cal Poly, Team 9-16, Regan Spring 2014
CPSU-REGAN-S14S9G16
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 1,167
