Ga door naar hoofdinhoud
Blackberry Storm 9530 Battery Replacement
Wat je nodig hebt
  1. Blackberry Storm 9530 Battery Replacement, Back Cover Removal: stap 1, afbeelding 1 van 3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: stap 1, afbeelding 2 van 3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: stap 1, afbeelding 3 van 3
    • Locate the two switches toward the bottom corners of the device's back cover.
    • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
    • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
  2. Blackberry Storm 9530 Battery Replacement: stap 2, afbeelding 1 van 1
    • Identify that the battery is visible once the back cover has been removed, and locate the battery in the rectangular-shaped top half of the device.
    • Pry apart the battery and back of the device using the flat end of your spudger tool or using your finger if you do not have a spudger.
    • Your battery has a specific orientation resembling a horizontal rectangle. Make sure the gold colored leads are aligned with the gold colored strips on your battery before reassembling.
Conclusie
melanie lim
607 Reputatie
6 handleidingen geschreven
Cal Poly, Team 9-16, Regan Spring 2014 Lid van Cal Poly, Team 9-16, Regan Spring 2014
CPSU-REGAN-S14S9G16
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 1,485
