Ga door naar hoofdinhoud
Blackberry RIM 7250 Front Housing Replacement
Wat je nodig hebt
  1. Blackberry RIM 7250 Front Housing Replacement, Battery: stap 1, afbeelding 1 van 3 Blackberry RIM 7250 Front Housing Replacement, Battery: stap 1, afbeelding 2 van 3 Blackberry RIM 7250 Front Housing Replacement, Battery: stap 1, afbeelding 3 van 3
    • Push the release button down and away from the device.
    • Slide the cover off toward the bottom of the device, revealing the battery compartment.
  2. Blackberry RIM 7250 Front Housing Replacement: stap 2, afbeelding 1 van 3 Blackberry RIM 7250 Front Housing Replacement: stap 2, afbeelding 2 van 3 Blackberry RIM 7250 Front Housing Replacement: stap 2, afbeelding 3 van 3
    • Place your finger in the groove next to the battery.
    • Lift your finger up to eject the battery from the battery compartment.
  3. Blackberry RIM 7250 Front Housing Replacement: stap 3, afbeelding 1 van 3 Blackberry RIM 7250 Front Housing Replacement: stap 3, afbeelding 2 van 3 Blackberry RIM 7250 Front Housing Replacement: stap 3, afbeelding 3 van 3
    • Remove the battery from the compartment.
  4. Blackberry RIM 7250 Front Housing Replacement, Back Housing: stap 4, afbeelding 1 van 2 Blackberry RIM 7250 Front Housing Replacement, Back Housing: stap 4, afbeelding 2 van 2
    • Remove the four 10.7 mm Torx T6 screws.
  5. Blackberry RIM 7250 Front Housing Replacement: stap 5, afbeelding 1 van 2 Blackberry RIM 7250 Front Housing Replacement: stap 5, afbeelding 2 van 2
    • Remove the two 5 mm Torx T6 screws.
  6. Blackberry RIM 7250 Front Housing Replacement: stap 6, afbeelding 1 van 1
    • Hold the phone with one hand, with the bottom facing toward you.
    • For both clips, insert the plastic opening tool and push away from you.
    • You will hear a clicking sound for each clip that is released.
  7. Blackberry RIM 7250 Front Housing Replacement: stap 7, afbeelding 1 van 3 Blackberry RIM 7250 Front Housing Replacement: stap 7, afbeelding 2 van 3 Blackberry RIM 7250 Front Housing Replacement: stap 7, afbeelding 3 van 3
    • Grab the back housing from the bottom and lift the housing away from you.
  8. Blackberry RIM 7250 Front Housing Replacement, Front Housing: stap 8, afbeelding 1 van 2 Blackberry RIM 7250 Front Housing Replacement, Front Housing: stap 8, afbeelding 2 van 2
    • Place your thumb on the bottom rectangle and your index finger on the top rectangle.
    • Squeeze your fingers together to release the internals from the front housing.
  9. Blackberry RIM 7250 Front Housing Replacement: stap 9, afbeelding 1 van 3 Blackberry RIM 7250 Front Housing Replacement: stap 9, afbeelding 2 van 3 Blackberry RIM 7250 Front Housing Replacement: stap 9, afbeelding 3 van 3
    • Pull the two pieces apart to separate the front housing from the internals.
Conclusie
Noah Eckert
519 Reputatie
5 handleidingen geschreven
IUPUI, Team S2-G4, Baechle Fall 2018 Lid van IUPUI, Team S2-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 99
