Ga door naar hoofdinhoud
Blackberry Pearl 8100 SIM Card Replacement
  1. Blackberry Pearl 8100 SIM Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. Blackberry Pearl 8100 SIM Card Replacement, SIM Card: stap 3, afbeelding 1 van 1
    • Slide the larger of the two metal casings upward (in the direction pointed to as “unlock”).
  3. Blackberry Pearl 8100 SIM Card Replacement: stap 4, afbeelding 1 van 1
    • Lift the metal casing.
    • Insert an SD Card.
Conclusie
Robert Cronin
544 Reputatie
6 handleidingen geschreven
Cal Poly, Team 34-57, Forte Spring 2010 Lid van Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 9,186
